Forums › Shopping du technicien astromech › Runs en cours sur astromech.net › Power distribution board
- Ce sujet contient 19 réponses, 6 participants et a été mis à jour pour la dernière fois par Anonyme, le 12 Nov. 2013, 21:12.
17 mars 2013 à 16:20 #6636Anonyme
Réalisé par Dan Stuettgen http://astromech.net/forums/showpost.php?p=173310&postcount=55 ” class=”bbcode_url”> http://astromech.net/forums/showpost.php?p=173310&postcount=55 La notice :
http://www.diverstrucs.com/fichiersforum/12%20volt%20power%20board%20instructions.pdf ” class=”bbcode_url”> http://www.diverstrucs.com/fichiersforum/12%20volt%20power%20board%20instructions.pdf Quote:Ok Guy and gals, many have you asked for it as you missed out on the last run, so here is your chance.
This is the offical notice for Run #10 of my power distribution boards. This will be the same as the last version. In case you wish to see a photo of it, you can go to the Yahoo R2 Builders group files section and look for the instructions for the board. The photos are in it. The version is the same as the 2.2 USB version except that there is a 6V regulator added. ( Note The USB connector is only used as an output connector to power USB devices requiring 5V – it is not an input or data connector)
The Board will have (2) 5V, (1) 6V (2) 9V regulators with (2) 12V pass throughs. I will try and figure out how to post a photo of the board from the last run.
Price is $52.00 each
Postage:
Domestic Orders for one board is $5.00, 2 boards is $6.00
International Orders for one board is $10.00, 2 boards is $13.00
Please note that as of January 31st 2013, the US post office drastically increased the postage rates for international mail. Doubling the rate at which was charged in 2012. This is the lowest rates I can get to ship these. FEDEX and Express mail are in the $30.00 to $40.00 range so I do not wish to use them.
When I ship international, I note on the customs form a price of $10.00, so that you won’t have to pay custom duties.
I am accepting paypal payments as of now till midnight March 31st US CST for this run of boards. At that time I will close the ordering process and then have the board house start making the bare boards and I will also order the components.
Paypal address is “droidmech2002 @yahoo .com” ( remove the spaces in front of the @ and . so you will have the correct email address)
So there you go. The run is on.
Dan S.
Houston R6 Builder – The First R6 unit.
17 mars 2013 à 16:52 #29385merci d’avoir relayé l’info, j’ai déjà un circuit de Dan et la qualité est bonne. après ce n’est pas forcément un circuit infaisable soit même… 17 mars 2013 à 21:52 #29386Il y a des choses un peu équivalentes sur ebay ou magasins, mais là c’est le plaisir d’avoir un truc un peu unique fait pour nous j’en ai un aussi, grandement utile !
19 mars 2013 à 19:24 #29387Anonymecette carte permet quoi exactement? 19 mars 2013 à 19:59 #29388tu l’alimentes en 12V et tu resors avec 2 sorties 5V, 2 sorties 6V, sortie USB, 2 sorties 9V et 2 pass thru 12V. c’est une carte qui permet d’avoir plusieurs tensions dans le robot 19 mars 2013 à 20:57 #29389AnonymeC’est intéressant pour brancher sur une batterie 12V des éléments comme un Raspberry PI ou un Arduino en 5V usb, des servos, des écrans lcd en 12V (teasing… ce que j’essai de faire pour les FLD et RLD… ) de la télécommande en 6V (si je ne me trompe). Bref, bien utile !
18 avril 2013 à 14:22 #29390AnonymeSalut, avez vous profiter de ce run ?
si oui avez vous été livrer ?
car pour ma part je n’ai rien reçu !!
18 avril 2013 à 16:39 #29391AnonymeA ma connaissance, les expéditions n’ont pas encore commencées, normalement l’assemblage des cartes doit être en cours. 29 juin 2013 à 10:00 #29392AnonymeLes livraisons ont commencées ! 5 juillet 2013 à 11:55 #29393AnonymeReçu ce matin. Nickel. Belle carte. 11 novembre 2013 à 12:30 #29394Nouvelle production de cartes d’alimentation. http://astromech.net/forums/showthread.php?t=16539http://astromech.net/forums/showthread.php?t=16539” class=”bbcode_url”> Quote:Ok Guys and Gals, many have you asked for it as you missed out on the last run, so here is your chance.
This is the official notice for Run of my power distribution boards. This will be the same as the last version. In case you wish to see a photo of it, you can go to the Yahoo R2 Builders group files section and look for the instructions for the board. The photos are in it. The version is the same as the 2.2 USB version except that there is a 6V regulator added. ( Note The USB connector is only used as an output connector to power USB devices requiring 5V – it is not an input or data connector)
Postage:
I am accepting paypal payments as of now till midnight November 30th US CST for this run of boards. At that time I will close the ordering process and then have the board house start making the bare boards and I will also order the components.
Paypal address is “droidmech2002 @yahoo .com” ( remove the spaces in front of the @ and . so you will have the correct email address) Please be sure that you have your correct mailing address in your paypal account as that is the address I will be shipping to as I use the shipping label in paypal
Dan S.
11 novembre 2013 à 13:37 #29395Anonymec’est un peu cher pour un truc fait avec quelques régulateur 78xx. Non pas que ca soit cher compte tenu de la réalisation (c’est ce que ca me couterait si je faisais un circuit imprimé à l’unité, sans doute) mais : – En terme de compos + carte pastillée, ca doit avoisiner les 10€
– je vous mets en garde vis à vis des régulateurs linéaires. La dissipation thermique est énorme, surtout pour un saut de 12+V à 5v.
Le 5V est très gourmand sur un droid, somme faite des servos + carte élec + éclairage, pour ne citer que ça. Pour ma part, je m’oriente vers des régulateurs à découpage “propre” du genre de dimension engineering (comme ce qu’à acheté sutaibot) mais d’une autres marques, traco pour ne pas la citer (utilisé depuis une dizaine d’années au boulot)
6A
http://fr.farnell.com/tracopower/tos-06-12sil/convertisseur-dc-dc-pol-6a-5v-sil/dp/1007593?Ntt=1007593 ” class=”bbcode_url”> http://fr.farnell.com/tracopower/tos-06-12sil/convertisseur-dc-dc-pol-6a-5v-sil/dp/1007593?Ntt=1007593 1A subminiature
http://fr.farnell.com/tracopower/tsr-1-2450/convertisseur-dc-dc5v1asip/dp/1696320?Ntt=1696320 ” class=”bbcode_url”> http://fr.farnell.com/tracopower/tsr-1-2450/convertisseur-dc-dc5v1asip/dp/1696320?Ntt=1696320 16A – un peu cher, mais ca doit faire assez pour l’intégralité du droid, ou en tout cas pour le dome. Je mettrais un ou deux 6A dans le corps.
http://fr.farnell.com/tracopower/tos-16-12sm/convertisseur-dc-dc-pol-16a-5v/dp/1007588?Ntt=1007588 ” class=”bbcode_url”> http://fr.farnell.com/tracopower/tos-16-12sm/convertisseur-dc-dc-pol-16a-5v/dp/1007588?Ntt=1007588 avec les régulateurs à découpage, quand la freq de découpage est élevé est les inductances de bonne qualité, on avoisine les 96% de rendement, plutot que d’envoyer des watts en effet joule avec les réguls linéaire. Ok la sortie comporte souvent 50 ou 100 mV d’ondulation, mais c’est sans conséquence. Un run sur astromech propose un circuit sur base d’un régul à découpage (le PCB n’est que pour la connectique autour).
11 novembre 2013 à 16:11 #29396Pour moi qui ne comprend pas grand chose à ces histoire de régulateurs, l’avantage de la carte de Dan, c’est que tout est opérationnel, testé et retesté en utilisation réelle et que c’est du prêt à être utilisé. Cela dit à l’heure actuelle je ne me sers que de 3 des sorties, mais bon, on branche et ça marche
Et puis vu ce que tirent mes NPC, je doute que le reste mange tant que ça sur la batterie
11 novembre 2013 à 16:30 #29397AnonymeXoff wrote:Pour moi qui ne comprend pas grand chose à ces histoire de régulateurs, l’avantage de la carte de Dan, c’est que tout est opérationnel, testé et retesté en utilisation réelle et que c’est du prêt à être utilisé.
Le fait que ca soit une carte toute faite et testé c’est très bien, mais c’est une question de design, les régulateurs linéaires sont obsolètes pour ce type d’application (je parle de distribution d’énergie).
Un régulateur 78xx c’est très bien pour l’alim d’une carte unique, genre pour alimenter *un* arduino sur du 12V (et encore, ca va chauffer rapidement).
ca n’a rien à voir. Ce n’est pas un soucis de consommation absolue ou que les moteurs proportionnellement pompent plus que le reste. Le soucis est PUISSANCE dissipée. Elle se calcule part la différence entre la tension d’alim et la tension de sortie du régul, le tout multiplié par le courant consommé.
Donc par exemple avec 12V régulé en 5, avec 1A on arrive à 7W (autant dire que tu ne touches pas le régulateur). Le servo consomment bcp plus qu’on ne croit. Certe ils ne bougent pas tout le temps et peut éventuellement se mettre en veille, mais le cumul de toutes les cartes et des lumières, va faire chauffer beaucoup une carte de distribution comme cette ci.
Ce que je reproche au design, c’est qu’au final, tu as une grosse carte avec plein de sortie (pour diviser la puissance sur plusieurs régulateur) alors que tu peux faire un meilleur travail avec un régulateur unique (ou juste en séparant 1 pour le dome et un pour le corps). Sutaibot confirmera peut etre
Relire sontpost sur la conso et la régulation
http://r2builders.fr/forum/viewtopic.php?f=26&t=2590&start=390#p18418 ” class=”bbcode_url”> http://r2builders.fr/forum/viewtopic.php?f=26&t=2590&start=390#p18418 encore une fois, je ne critique pas le fait que quelqu’un propose un produit via un run. Mais le fait que quelque chose soit dispo ne veut pas dire que c’est murement réfléchit comme design.
11 novembre 2013 à 22:32 #29398je suis tout à fait d’accord, s’il y a mieux, on aurait tort de s’en priver je mettrai les doigts sur les régulateurs la prochaine fois, mais honnêtement en utilisation réelle, j’ai quand même des doutes sur ces histoires de chauffe abusive
je pense que c’est vrai en utilisation intensive (ou en calculant sur une feuille), mais je testerai la chaleur du bidule quand j’utilise r2
dans l’absolu, le calcul serait intéressant de savoir combien on perd en autonomie (c’est cela que je voulais dire en mentionnant la consommation des NPC)
honnêtement que mon droide roule 3h ou 3h et 5 minutes, c’est pas catastrophique pour moi
mais bon, le second design de carte peut être intéressant, de mémoire je crois que c’est Chris qui les proposait, non ?
