- Ce sujet contient 14 réponses, 14 participants et a été mis à jour pour la dernière fois par Anonyme, le 12 Déc. 2018, 12:11.
17 mars 2013 à 22:03 #6639
L’ensemble des sons est téléchargeable, je vous laisse le commentaire original posté sur astromech par Ben Lewitt Quote:181 files sorted and named per the JEDI’s categories but you can name them as you see fit. The CF files will need to be renamed to suit those systems.
Included in each zip are every sound R2 makes in ANH sourced from the Sideshow R2 and are as clean as we’ve had available in the formats required for the three main audio systems in use in our hobby.
Mono WAV 22KHz (8bit)
https://dl.dropbox.com/u/22092773/CFII.zip Stereo WAV 44KHz
https://dl.dropbox.com/u/22092773/CFIII.zip Stereo MP3 VBR
https://dl.dropbox.com/u/22092773/JEDI.zip DooDoo and WolfWhst are not from ANH but I tried to match them to the others as far as matching volume and cleaning up noise. The Leia is also a custom version that removed background sounds and added a synth to mask the ones that couldn’t be removed easily. Also included is the Interactive R2 cantina song.
Alarm1-11 (Generic sounds of an alarmed R2)
Annoyed
Cantina (Interactive R2 Cantina Song)
Chortle
DooDoo (Updated to clean file)
Failure
Groan
Hum1-25 (Generic hum or muttering sounds)
Leia (Slight synth effect to voice and crackle at end of message)
Misc1-36 (These are sounds that didn’t fit a specific category well)
MOTIVATR (R5-D4’s Motivator sound)
Ooh1-7
Overhere
Patrol1
Proc1-15 (Generic chirpy process sounds)
Question
Razz1-23 (Generic rude sounds)
Scream1 (Short scream from Jawa attack)
Scream2 (Short scream from TIE fighter blast)
Scream3 (Long scream effect from Jawa attack.. includes SHORTCKT and “groan”)
Scream4 (Long scream effect from TIE fighter blast… includes “failure”)
Sent1-20 (These were items that fit multiple categories and sounded like… well sentences rather than words)
Shortckt
StartSnd (Sound Scott uses for Startup sound for JEDI)
Whist1-25 (Effects dominated by whistle)
WolfWstl
Wowie
While there were memorable/unique sounds that existed in other films, I think these constitute a majority of the sounds R2 makes. I’d sure love to get similarly clean files from other films… no background music, no folly, no static and preferably not cut short as many of the sounds I’ve seen floating around.
18 mars 2013 à 00:19 #29443AnonymeSuper !!! Merci
18 mars 2013 à 05:08 #29444AnonymeMerci :welldone: 18 mars 2013 à 17:32 #29445AnonymeCool. C’est bon ça
18 mars 2013 à 20:39 #29446AnonymeJe dirais même plus : c’est bon ça :clapclap 20 mars 2013 à 13:46 #29447Jackpot !!!! :dance: merci !20 mars 2013 à 16:16 #29448M E R C I :welldone: 20 mars 2013 à 20:05 #29449Anonymemerci :amen: 19 août 2017 à 08:15 #29450Anonyme:amen: Super, merci19 août 2017 à 08:51 #29451AnonymeMerci
4 octobre 2018 à 15:50 #29452Anonymebonjour le lien ne fonctionne plus quelqu’un aurait un fichier avec les sons en mp3 s’il vous plait? 4 octobre 2018 à 19:08 #29453AnonymeJe dois avoir sur mon pc. Je regarde demain et je te fais signe si c’est bon. 8 octobre 2018 à 10:30 #2945412 décembre 2018 à 08:16 #29455AnonymeCool merci
12 décembre 2018 à 12:11 #29456AnonymeExcellent -
