Sons R2
  • #79111
      L’ensemble des sons est téléchargeable, je vous laisse le commentaire original posté sur astromech par Ben Lewitt
      Quote:
      181 files sorted and named per the JEDI’s categories but you can name them as you see fit. The CF files will need to be renamed to suit those systems.
      Included in each zip are every sound R2 makes in ANH sourced from the Sideshow R2 and are as clean as we’ve had available in the formats required for the three main audio systems in use in our hobby.
      Mono WAV 22KHz (8bit)
      https://dl.dropbox.com/u/22092773/CFII.zip
      Stereo WAV 44KHz
      https://dl.dropbox.com/u/22092773/CFIII.zip
      Stereo MP3 VBR
      https://dl.dropbox.com/u/22092773/JEDI.zip
      DooDoo and WolfWhst are not from ANH but I tried to match them to the others as far as matching volume and cleaning up noise. The Leia is also a custom version that removed background sounds and added a synth to mask the ones that couldn’t be removed easily. Also included is the Interactive R2 cantina song.
      Alarm1-11 (Generic sounds of an alarmed R2)
      Annoyed
      Cantina (Interactive R2 Cantina Song)
      Chortle
      DooDoo (Updated to clean file)
      Failure
      Groan
      Hum1-25 (Generic hum or muttering sounds)
      Leia (Slight synth effect to voice and crackle at end of message)
      Misc1-36 (These are sounds that didn’t fit a specific category well)
      MOTIVATR (R5-D4’s Motivator sound)
      Ooh1-7
      Overhere
      Patrol1
      Proc1-15 (Generic chirpy process sounds)
      Question
      Razz1-23 (Generic rude sounds)
      Scream1 (Short scream from Jawa attack)
      Scream2 (Short scream from TIE fighter blast)
      Scream3 (Long scream effect from Jawa attack.. includes SHORTCKT and “groan”)
      Scream4 (Long scream effect from TIE fighter blast… includes “failure”)
      Sent1-20 (These were items that fit multiple categories and sounded like… well sentences rather than words)
      Shortckt
      StartSnd (Sound Scott uses for Startup sound for JEDI)
      Whist1-25 (Effects dominated by whistle)
      WolfWstl
      Wowie
      While there were memorable/unique sounds that existed in other films, I think these constitute a majority of the sounds R2 makes. I’d sure love to get similarly clean files from other films… no background music, no folly, no static and preferably not cut short as many of the sounds I’ve seen floating around.
      #101924
        Super !!! Merci :)
        #101925
          :welldone:
          #101926
            Cool. C’est bon ça 8-)
            #101927
              Je dirais même plus : c’est bon ça :clapclap
              #101928
              Padawan-49
                Jackpot !!!! :dance: merci !
                #101929
                woozoom
                  M E R C I :welldone:
                  #101930
                    merci :amen:
                    #101931
                      :amen: Super, merci
                      #101932
                        Merci ;)
                        #101933
                          bonjour le lien ne fonctionne plus quelqu’un aurait un fichier avec les sons en mp3 s’il vous plait?
                          #101934
                            Je dois avoir sur mon pc. Je regarde demain et je te fais signe si c’est bon.
                            #101935
                              Pour Ceux qui recherchent les sons comme stium, c’est ici
                              #101936
                                Cool merci :)
                                #101937
                                  Excellent
